Having trouble reading v7.3 MATLAB mat file with MATLAB Data Plugin [1.4.06900]
Hi guys,
I tried to read some mat files with MATLAB Data Plugin [1.4.06900]. The vi works perfect with v5 or v7, but not able to read v7.3. Is anyone having this issue as well?
I am using LabVIEW 2016 Professional and MATLAB 2017a.
Thank you very much.
https://www.ni.com/en/support/downloads/dataplugins/download.ni-dataplugin-for-matlab--mat-files.htm...
File Extension: *.MAT
Direction: Read / Write
Last Change: November 22, 2017 [1.4.06900]
Update Information:
The following changes have been made to this version:
  •  Added support for MATLAB version 7.3 files
https://www.mathworks.com/help/matlab/import_export/mat-file-versions.html
(4,824 Views)
Hi gangxu,
Do you have a sample data set that we could use to try and reproduce this in-house?
Matt | NI Systems Engineering
(4,781 Views)
Hi Matt,
Thanks for you reply.
To run this test vi, please install MATLAB data plugin.
I've have a couple of mat files attached in the zip file.
The mat files have identical variables inside.
>> save('D:\MAT_file_v7.3.mat','sine_signal','cosine_signal','-v7.3');
>> save('D:\MAT_file_v7.mat','sine_signal','cosine_signal','-v7');
>> save('D:\MAT_file_v6.mat','sine_signal','cosine_signal','-v6');
>> save('D:\MAT_file_v4.mat','sine_signal','cosine_signal','-v4');
Only v7.3 mat file fails.
Screenshot - 2_5_2018 , 11_03_11 AM.pngScreenshot - 2_5_2018 , 11_03_11 AM.png
(4,777 Views)
Really solid description - I reproduced this here and will let our DataPlugin R&D know.  Are you able to work around this for the time being or has this stopped your development?
(4,765 Views)
Hi Matt,
Thanks for the support. I can deal with the mat file reading later. No big issue. Just wanna make sure it is a bug or my misunderstanding.
Thanks again.
Gang
(4,761 Views)
No problem.  Like I said, I looped in our DataPlugins team and they're in the process of digging into this.  I can't comment definitively on when the fix will be available but we'll keep you updated.
(4,750 Views)
Thanks Matt.
(4,748 Views)
