We are trying to scal readings (see example code) and store them to a file yet I am having trouble getting the correct time stamp.
Once I change the readings to DDT, perform the calculations then convert back using DDT I lose the correct timestamp.
I have tried changing the DDT time to both Zero and Now without any luck.
The reason I need to scale the readings is for an "end to end" calibration I was given for 96 t-couple channels.
Would it be better if I entered this calibration data into Ni-Max instead?
Please take a look at the 2 files attached.
The "Good" file gets the data EXACTLY how I want it but it is not scaled.
The "Incorrect" file is scaled but not how I want it.
Any help is appreciated!
thanks
mike
