Having trouble using CAN drivers
Hello, I am trying to use CAN functions in another computer but I am not able to, the error I get is 0x00200 which means Drivers are not found. Do I have to directly download them in the computer? Or can I transfer them from another computer (since the one I'm using does not have Internet connection)
(1,519 Views)
You have to install the appropriate driver on any computer that you're going to run your application.
NO, copy-paste from one computer will now work for drivers. You can download an offline installer and use it on the computer without the internet.
Santhosh
Soliton Technologies
(1,511 Views)
Assuming it is a NI CAN device you will need to download and install the NI-CAN drivers
=== Engineer Ambiguously ===
(1,493 Views)
