Having trouble with Interpolate 1D array
I am new to Labview, and I am having trouble with the Interpolate 1D array function. I have attached a sample vi and some sample data.
What I find is that the interpolated y-values produced are just the first n number of y-values input in the array of numbers, where n is the number of y-values required. I am obviously misunderstanding something, but as far as I am aware the array of numbers that I am inputting (in the rawData example file attached) corresponds to a cluster of x and y-coordinates, as shown here: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/interpolate-1d-array.html.
I have also examined the Labview interpolate example and examined this thread: https://forums.ni.com/t5/LabVIEW/Can-you-give-me-an-example-using-the-vi-interpolate-1d-array-vi/m-p... but both just deal with fractional indexes rather than x-values.
Any help inunderstanding ,y mistake would be appreciated.
(5,285 Views)
Accepted by topic author cohara85
Hi cohara,
I guess you want to interpolate Y values (from 2nd column) based on X values (in 1st column).
Try this:
(It's an Index&BundleClusterArray function inside…)
(5,266 Views)
Thank you GerdW.
Is see now what is meant by a cluster.
However I am now getting the rror message: 'The type of the source is cluster of 2 elements. The type of the sink is a 1-D array of double.' Does this imply that the interpolate function cannot accept a clustered input? I am using Labview 7.1.
(5,250 Views)
Hi cohara,
did you disable autoindexing on the input tunnel as is shown in my snippet?
(5,242 Views)
Thanks again GerdW,
I hadn't disabled autoindexing. It's working now 🙂
(5,229 Views)
