Having trouble with report generation formatting
Hello!
I am having trouble formatting the Excel document when using report generation. I want a reading recorded for my two pressure transducers, two load cells, and thermocouple every second with each sensor assigned to a column in one Excel document (with the time in the first column). Right now multiple Excel documents are created at each time step showing a 5X2 matrix with the current time of the test in the first column and the current value of the five sensors in the second column.
Thank you,
Claire
(2,547 Views)
Do not create a new report inside the loop, create it before the loop. Then carry the report in a shift register. You can use transpose 2d array if the data is not oriented correctly.
(2,541 Views)
Have you read the Help for all of the RGT functions?  Have you looked at any of the RGT examples?  Here's a Leading Question -- what is the name of the Excel file that you think you are writing?  Do you have one name or multiple names?
Bob Schor
(2,514 Views)
Thank you, gregoryj. I appreciate your help!
(2,492 Views)
