Having trouble writing a PWM train to 12V case fan (USB-6215)
While I appreciate the tip regarding execution highlighting, I wouldn't have asked these questions without first using said execution highlighting function. I try to limit my questions to instances when I'm intractably stuck, such as this. When I used execution highlighting, everything appeared to run fine. Unfortunately, the problems that I described were unable to be diagnosed with execution highlighting. Is there any advice other than 'use execution highlighting' that you may be able to provide?
Message 11 of 12
(362 Views)
Code outside a loop only executes once (ie, your DAQ Assistant). A loop doesn't repeat until all the code inside it finishes, including nested loops. If you ran your code with execution highlighting you'd see that the DAQ assistant only runs once, before the loop starts. On the first cycle of the outer loop it gets stuck in the inner loops and never loops again. Finally, indicators outside a loop that are fed by data coming out of a loop, such as the humidity difference, don't receive data until the loop exits. Are you sure everything ran fine with execution highlighting?
Message 12 of 12
(356 Views)
