Heater Control
Thank you so much RavensFan (Knight of NI),
I think the on/off controller is simpler and I might be going with it. I took a cursory look at the examples in LabVIEW for an on-off controller but it seems I'm not able to relate it with connecting with my DAQ. This will be my first control project.
Operations, Hookes Electric Limited
Message 11 of 15
(1,448 Views)
Message 12 of 15
(1,445 Views)
@hookes2 wrote:
Hello Everyone,
Please I have a furnace which I want to control the rate of heating of the heater. I have the following hardware: cDAQ 9172, NI 9211, NI 9474 and a K-type thermocouple. The specificatio of the heater is as follow:
Maximum Temp: 1600
Voltage: 240 Volts
Watts: 4500
Amps Max: 43.6
Thanks!
daq DO to SSR (5VDC to 240VAC/60A)...Smiley Wink
Message 13 of 15
(1,427 Views)
Glad you found a solution.
Certified LabVIEW Architect
Message 14 of 15
(1,400 Views)
Many thanks to you all. Apart from finding a solution to my problem, I also learnt a new lesson. I usually overlook questions that people post on the forum even when I obviously have a solution to it hoping someone else does it. From now on, I have resolved within myself to be active on this forum and help as many people as I can help. Thanks once again. With love from Nigeria!
Message 15 of 15
(1,391 Views)
