Hello ! How can i change the mechanical action type of a boolean control at runtime ? there is no property ...
As long as there's no property node for that, you could use local or global variables to simulate different mechanical actions, making button act differently, but i think is too many work for that. Why do you need this?
Message 2 of 8
(3,677 Views)
Hy !
thanx for ya fast answer !
My problem:
I need at runtime two different mechanical actions with only one boolean control:
1. switch until released
-> the user can activate more than one control
2. switch when pressed
-> the user can activate only one control
you can see the function in the attached file
OK CU.
JohnZ
Message 3 of 8
(3,677 Views)
For i can see (not much, i only have LV 5.0 and couldn't open the example) you could use an example called "Radio buttons" that make only one button selectable from a set of buttons and deactivate it when you need more than one selected. I think radio button example is in LV examples.
Hope this helps, if not, send the example in LV 5 and i'll check it.
Message 4 of 8
(3,677 Views)
hy again !
i have attached the 5.0 Version...
the radio buttons solution is not that what i need, ok i must hide the buttons..
OK CU.
JOHNZ
Message 6 of 8
(3,677 Views)
I think your best bet is to use the property nodes. Have one boolean that switches when pressed, and it one state should be "activate all controls", and the other state should be "activate one control".
If "activate one control" has been selected, then when one of the control buttons is selected as true, disable the other controls.
If "activate all controls" is selected, then don't disable any controls; leave them all active.
Mark
Message 8 of 8
(3,677 Views)
Have the two type of boolean controls on your panel but have your default switch set to show and set the other to hide. Instead of trying to change the mechanical properties of one switch, hide and show the relevant switches with the correct mechanical properties.
Ray.
Regards
Ray Farmer
Message 5 of 8
(3,677 Views)
