Hello! I just want to know how to open a document (.pdf or .doc).
I have looked at Labview\vi.lib\platform\browser.llb\Open a Document on Disk.vi but the vi has many subvi's. It works well but when I  build a new application I always get errors when I try to open the document. Thank you.
(2,852 Views)
Duplicate post.  See this thread.
(2,844 Views)
I am not really sure if it is a duplicate, because if I read the question right, the problem occurs onyl in a built application.
Most likely you are using relative paths (realtive to "current VI path").
Here's a recent discussion that might be useful:
Good luck!
(2,825 Views)
Altenbach....  we're gonna start calling you "Hawkeye"  😄
There was not much info on the other post other than tst's reply..  I'll check it out..
Thanks buddy!
RayR
EDIT PORTION:
Humm...  the titles were similar....  "Hello! I just want to know how to open a document (.pdf or .doc) after the press of a control button. Thank you."
But you're right.. nothing mentioned about a build..  >> SORRY: Not Duplicate Post <<
Message Edited by JoeLabView on 09-21-2007 11:38 AM
(2,818 Views)
