Hello, I would like to produce 2 different pulse trains on the CTRo and CTR1 output pins.
(DAQ-CARD E6024 PCMCIA)I have the 2 output pins monitored on my scope, when CTR0 puts out a pulse train, CTR1 goes high. When CTR1 puts out a pulse train CTR0 goes high. Also, the pulses are interleaved with each other. Is there a way to make then start at the same time
(2,679 Views)
test
(2,679 Views)
Hello Zoltan,
I would suggest using the counter gates to synchronize the counters. You will need to externally run a wire from one of the DIO lines you're not using to one of the counters' gates. When the counter gate is high, the pulse train will be generated on each counter. Both counters will need to use the same PFI line as the gate.
There is an example program that ships with LabVIEW 7 called "Gen Dig Pulse Train-Continuous-Pause Trigger" for DAQmx. This demonstrates how to configure the counter to only generate the pulse train when the gate is high.
With this configuration, you could synchronize the counters by writing to the DIO line which is wired to one of the counter gates when you're ready to start the pulse train generation.
Hope t
his helps.
Kristi Hummel
(2,679 Views)
