Hello everyone. I am looking a specific NI hardware that can read digital output and implement sqlite database.
I already have ni usb 6501. Is ni 6501 capable to this. Thank you/
(1,255 Views)
Hi Henry,
First advice: use a shorter, but still descriptive message title. Put the question into the message text!
Next advice:
The USB6501 is a DAQ device, capable of digital IO as can be read in its datasheet. As such it will not "implement a sqlite database"!
You need to implement the database access in your software, but not "in the hardware"…
(1,218 Views)
As far as the DIO, using DAQmx to control the USB-6501 is pretty easy.  Just look up an example and use that as a starting point (Help->Find Examples).
For SQLite, I hear great things about this library: SQLite Library
(1,193 Views)
