Help Creating Pulse Frequency Modulated Signal
I'm trying to create a Pulse Frequency Modulated Signal ... I have seen the examples showing how to create a frequency modulated sine wave (using the function generator example, I believe) but am not sure where to look next.
Any suggestions?
For some context, this would be used to simulate the signals similar to those found traveling through/ transmitted through a nervous system.
Thanks for the help!
(3,026 Views)
So, I found the Biomedical Workbench. From the description it looks like I can "generate a synthetic biosignal". Unless I'm misunderstanding, it seems like the data to generate it has to come from a DAQ. Is there a way to have a "standard" signal generated... like from an ECG?
(3,016 Views)
Hello Slow,
You can generate ECG signals using the Biosignal Generator by changing the Signal type in the pull-down menu. Take a look at this description.
Alina M
(3,001 Views)
