Help: DAQ error on digital output.
I use a MIO-16E board on my Mac G4. Its analog input and analog output work
fine. However, whenever I use digital output, I get a error code -10008,
which means "the group is invalid" (?). This error is generated by "DIO port
Write".
Does anyone know what it really means? Even the examples come with LabVIEW
get the smae error message. Your help is appreciated.
(3,147 Views)
I believe that the default for digital i/o is that they are configured as
inputs. If you didn't use DIO Config to set them as ouputs, that might explain
the error message.
work>fine. However, whenever I use digital output, I get a error code -10008,>which
means "the group is invalid" (?). This error is generated by "DIO port>Write".>>Does
anyone know what it really means? Even the examples come with LabVIEW>get
(3,146 Views)
