Help! Getting 9 columns from an 8 column listbox.
I'm creating a program that controls an environmental chamber for. Right now I am doing the piece that creates and edits profiles (ProfileEditor.vi), and somehow I seem to be getting 9 columns out of an 8 column listbox. I suspect that it is somewhere in my StepEditor.vi, but I don't see it in the logic. Can anyone see what I am missing?
Simon
(3,662 Views)
Accepted by topic author SimonGoodson
You need to tell Array to Cluster how many elements you want, the default is nine as you have discovered. Just right-click on it and set it to 8.
(3,660 Views)
The default output of the Array to Cluster is 9 elements. It does not autosize. Just right click on it to set the size.
(3,659 Views)
You guys rock, than you so much. I thought I had it screwed up somewhere else!
Simon
(3,653 Views)
