Help/How to find GPIB?
Hi, all.
I am newhand to labview. Now I am trying to write a VI to control the x-ray
detector. To achieve this, I need to find the GPIB board inside my comuter.
I tried several "normal" methods such as adding hardware etc, but I could
not get my computer found it. If you know where the problem is and how to
get the bug away, could you please give me some idea? I must finish the VI
in three work days, but now I still could not find the GPIB board 😞 Thanks
very much for you help.
Best,
Fan
(3,797 Views)
Fan,
could you give us some more details about your problem? I.e. what OS, what
kind of GPIB-Board (PnP?) With the NI-Driver comes a nice installion utility
with some troubleshooting features, have you tried this ("Add GPIB Hardware"?
Peter
"Fan Zhang" wrote:
>Hi, all.>>I am newhand to labview. Now I am trying to write a VI to control
the x-ray>detector. To achieve this, I need to find the GPIB board inside
my comuter.>I tried several "normal" methods such as adding hardware etc,
but I could>not get my computer found it. If you know where the problem is
and how to>get the bug away, could you please give me some idea? I must finish
the VI>in three work days, but now I still could not find the GPIB board
😞 Thanks>very much for y
ou help.>>Best,>Fan>>
(3,797 Views)
You may not have to find the board at all. With Keithley boards, I never
install then (OK, I put them in the PC) but Windows never knows they are there.
I access the boards using the Keithlely driver DLL's and driver interface VI's
I wrote. This did not take 3 days (it was my first attempt at this also). If
you are new, my solution may not be of help. But I suggest you find out if the
board manufacturer has DLL's for accessing the board, and work from there. If
the board is NI or other large, well supported GPIB manufacturer then they
should have all the install software needed.
Henry
(3,797 Views)
Keithley boards stink. Try a National board. They install flawlessly and
are easy to program.
Henry Coulter wrote in message <39646832.DE3EECDE@loxinfo.co.th>...
there.
VI's
If
the
If
>Henry
(3,797 Views)
I have configured both type of boards, and although I do not push any of this
hardware to the limit, both NI and Keithley GPIB hardware seem perfectly
adequate. Unfortunately the company I work for has a policy to only purchase
Keithley equipment. So whether or not the board stink is a mote point, I must
use them. Perhaps other people are in a similar situation. Let's keep an open
mind.
However I totally agree that NI equipment installs.. how to put it.... like
a dream!
Henry
(3,797 Views)
We have a few of this GPIB
National Insturments GPIB Interface for PCI - $395.00 -
Brand New - TNT4882C and MITE ASICs provide maximum IEEE 488.2
performance -
Transfer rates up to 1.5 Mbytes/s using IEEE 488.1 handshake; up to 7.7
Mbytes/s
using HS488 - Onboard bus master DMA Controller ensures no
microprocessor
interruption for data transfers - NI-488.2 for Windows NT/98/95,
Solaris 2,
Mac OS, Digital Unix - For more
information on this product including
detailed datasheets visit
http://www.eio.com/micintro.htm#product
National Insturments GPIB Interface for ISA - $295.00 - Brand New -
Low-cost GPIB interface for ISA - NAT4882 ASIC provides maximum IEEE
488.2 performance - Transfer rates up to 300 kbytes/s - Half-size ISA
board fits any I/O slo
t- NI-488.2 for Windows 98/95/3.1, DOS - For more
For additional info or if you have any questions email sales@eio.com
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,797 Views)
