Help. I Need LabView 7.0 and PDA Module 7.01f
Hello!
I am a student currently  working on my final year project. I need to develop a Sound Vi using Labview for a PDA with Pocket PC 2002. However I cant find LabView 7.0 anywhere or the PDA Module. I have LabView 7.1 though. If there is any way around this please help.
Thank you
(3,011 Views)
Contact NI Tech Support directly (click the Contact NI link at the bottom of the pages). You'll need to provide them your key and they can provide you with a copy of LabVIEW 7. You can't use the forums for this kind of request, since there is no (legal) download location for old versions of LabVIEW.
(3,000 Views)
Thanks for the advice and speedy response
(2,997 Views)
Be aware that even if you do get these, you might not be able to do what you want. LV 7.0 had the first version of the PDA module and it was very limited and buggy at the time. I don't know what your requirements are (or why you're doing this using an old version of PocketPC instead of using something current like an iPhone or an Android device), but I would also suggest seeing if you can do this using another environment (such as eVC, if you remain with PocketPC).
___________________
Try to take over the world!
(2,995 Views)
