Help, I want this to turn off completely instead off waiting.
Instead of waiting for all the cases to finish, I want it to completely turn off when I switch off the button.
Thanks in advance guys.
(2,942 Views)
You must change you for-next loop to a while loop. Then set up the while loop to end if x>5 or if your switch is pushed.
Randall Pursley
(2,941 Views)
You mean replace the for loop to a while loop ? I did it but it wouldn't stop at all when i turn the switch off.
(2,906 Views)
Here is how the while loop should be hooked up.
Randall Pursley
(2,902 Views)
have you got it for 6.1 ?
(2,881 Views)
