Help: Logging Data from the DAQ Assistant
Hi there,
I am new to LabView and I am using it for a senior capstone project.
I am using the NI-9219 in combination with LabView's DAQ Assistant in order to read current signals from a couple of pressure transducers.
I am able to generate data and read it instantaneously in the DAQ Assistant but I can't figure out how to log it to a tdms or generally export the data to a spreadsheet and/or text file.
There is a logging tab within the DAQ Assistant and it says to "configure logging and then use the task in a development environment to begin logging to disk." I have no idea what that means.
can anybody give me a step-by-step on how I can get numerical data exported to a spreadsheet or something of the sort?
(1,806 Views)
Data Logging in NI LabVIEW With DAQ Hardware
You can search on ni.com for more articles.
(1,786 Views)
