Help: Model predictive control with references
Hi All,
I want to implement a model predictive control. I have 12 inputs. I want to control all these with references inputs and display.
I managed to implement this controller but I have problem with the inputs references.
Thanx you.
(3,676 Views)
What is the problem?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,670 Views)
mpc takes only two type of equations it should be either transfer function or than state space but my equation is non linear how can i get transfer function from that in labview?
(3,111 Views)
Hi shami_jadoon,
Thanks for posting a new thread for this question! Not only will it make the post more searchable, you are also likely to see higher traffic on new posts. It looks like Matt is helping you out for the time being, but I'll chip in as well if I have anything to add.
(3,079 Views)
