Help !!! NI MAX doesn't detect compactRIO 9063
I am currently using Labview 2019 for a project. I tried to connect CRIO 9063 to my computer by using an ethernet cable. I've already written the IP adress of the device. But NI MAX don't want to display the CRIO in the section "deported systems". I tried to write it manually but NI MAX says that "the drivers don't support this device". I don't really know what to do. Help me
(494 Views)
Can you connect your 9063 through the USB connector?  You can also use the Ethernet connection, but you then have to ask MAX to "find it" on the Network.  This NI note discusses how to get MAX to find it.
Let us know if this worked for you.
Bob Schor
(467 Views)
