Help. The Vi not executable. Thanks
(1) I can run this vi individual without any problem.
(2) after I build test sequence, it can not run.
(3) I checked all the vi at 2013 version.
Thanks for help.
see attached files.
Message 1 of 8
(6,209 Views)
Can you explain clearly which is your main vi and which vi has the problem and what your application does?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(6,174 Views)
Hi:
 (1) IRobot test engine is main vi
(2) Initailize DAQ_CMD_PERBR is try init the DAQ.
this vi is running fine when I run it individual.
but after build , it can not run .
Thanks for help.
Message 3 of 8
(6,152 Views)
Did you build and run an installer to install the needed runtime drivers?
Message 4 of 8
(6,147 Views)
Hi:
 do you mean 2013 labview runtime engine ?
 I have development 2013 labview version.
it should not need run time engine, is it right?
Message 5 of 8
(6,136 Views)
So you can run the VIs, what do you mean then by "after I build test sequence, it can not run." or "but after build , it can not run"
You are making them into an executable and then they can't run in your development machine, is that right?
Message 6 of 8
(6,111 Views)
If this is the case you may be missing adding the dynamic VIs dependencies when building the executable:
https://forums.ni.com/t5/LabVIEW/Executable-with-Dynamic-VIs/td-p/937434
https://forums.ni.com/t5/LabVIEW/Error-1003-when-dynamically-calling-VI-within-an-executable/td-p/29...
Do you call any VI dynamically? Are you using any toolkit/module?
Message 7 of 8
(6,109 Views)
Accepted by topic author zy6
Hi zy6,
the error message says: "DAQ_CMD_PERBR.vi is not executable when you try to open its VI reference in SeqUUTCmd.vi"…
This DAQ_CMD_PERBR contains a lot DAQAssistent calls: I "heard" that they have a tendency to get broken in executables.
Replace those DAQAssistent calls by plain DAQmx function calls and see, how far you get!
Edit: Please don't put "Help" and "Thanks" in the title of all your threads! It is clear you need help when you create a thread and you can thank by giving Kudos…
Message 8 of 8
(6,106 Views)
