Help!VISA write and read (for reading data from agilent N6701A )
I want to get maximum current value as ramping every power module,
but I can't get 2D Array including current values of 4 modules after running
this program,why?
please see my labview code , give me some advice.
I use agilent N6701A ( 4 modules with HSTE).
(2,912 Views)
Is the VI in LabVIEW 8.2?
Would it be possible to save it in LabVIEW 8?
(2,902 Views)
I save it to LV8.0, see attached file.thanks
(2,889 Views)
I don't have this instrument.
What is the output of the VISA Read? Can you post that string?
Are you having trouble just getting a 2D-array?
It looks like with this VI that you will get the results of only the last command. The first 3 commands are sent but no read is done.
Message Edited by nyc on 11-15-2006 11:31 AM
(2,884 Views)
