Help With Multiple Digital Grounds
I have a PXI-6259 (M-Series) hooked up to a SCB-68 terminal box.  I have 3 different electronic devices which produce digital signals that I want to monitor with the 6259.  However, If I combine the digital grounds for these DI input lines, I get a ground loop problem which causes my electronics to act erratically.
Is there a way to set a PFI line to use another PFI line to be the reference ground for that channel, sort of like a differential input?  Is there any other way to go about separating my digital grounds so as to prevent these ground loop problems?
Thanks.
Mike
(3,394 Views)
The best way to go is to use isolation modules.  I have always used the OPTO22 G4 series.  You will need either a 4 or 16 channel terminal board rack, and whatever digital input modules you need for your type of signal.
(3,388 Views)
That's what I was afraid of... additional hardware.   Any other suggestions?
Could I use the PFIs as analog input in differential format?  I have 4 channels with one ground, 4 with another, and 6 with the last.  I think the 6259 has 16 AI channels as I recall correctly.  Can I reference a single PFI line for the differential input on mulitple AI channels?  I think this is possible...
(3,381 Views)
Mike:
Can you post an image or a schematic or how the devices are powered and connected up to the DAQ card?
(3,375 Views)
Here's a schematic of how I have ti wired up right now.  Each axis (encoder) has its own electronics, although they appear to have the same power supply.  Each axis has it's own digital ground.  I think that I'm getting ground loops by connecting all digital grounds to the DGND of the SCB-68 which causes problems with the circuitry that reads the encoders.
I am trying to be as passive as possible and not affect these digital lines which I've tapped into on the equipment.
Message Edited by mschmit on 05-07-2007 11:02 AM
(3,370 Views)
You could try using shielded twisted pair wire with a shield.  ChA and ChA would be one twisted pair, B and B would be a second twisted pair, and the shield would be DGND.  Use this for all axes.  Ground only at one end, preferably at the end closest to the power supply.
- tbob
Inventor of the WORM Global
(3,355 Views)
