Help With Reading Excel for Labview To Make Graph with values
Hey, Guys, How are you ?
Im in trouble about this VI. With this VI I get informations about 2 sensors with daq assistant and write in a xlsx. But I want to read a excel file too, and with this reading make a graph. Someone can help me ?
I need more 2 things.
- Make a Control of frequency about my tax update.
(3,192 Views)
Can you be more specific ? I don't really understand what is the problem here and with which vi ?
One thing you can do is to log the files in .tdms, I think it will be more efficient than using different format,
(3,140 Views)
Hi William,
It's not the most intuitive to read data using the report generation toolkit. What you do is open a new report and in the template input you input your data file name. Then you use the "get data" VI from the RGT. Good luck, let me know if you need any more help!
(3,127 Views)
