Help a Noob manage many channels and build an elegant program
I'm looking for an example of how I can use clusters in this situation, not having much luck.
Message 31 of 33
(429 Views)
So with the help of the community here's what I have so far.
I'm running into some errors I don't understand and there's a cluster problem I'm not sure how to solve. "you have connected two clusters of different types, cluster of 9 elements conflicts with cluster of 16" I thought that this was an array to a cluster.
The other error has something to do with the (control index) not having an indicator?
VI attached
Message 32 of 33
(404 Views)
Ok, found out you can right click and set how many elements in the cluster. Changed the default 9 to 16 and that appears to have fixed that issue.
But this other one I'm not sure about so I'll start another thread.
Message 33 of 33
(398 Views)
