09-26-2003 01:05 PM
09-26-2003 02:48 PM
For encoder-based (synchronous) measurements, you want to connect the once-per-rev signal (encoder index) to the EXT TRIG input (I forget the PFI numbers), and the N-per-rev signal to the EXT. CLOCK input. Use the EXTERNAL DIGITAL + triggering option, and the EXTERNAL SCAN CLOCK option. Set the NUMBER OF SAMPLES TO ACQUIRE to match your encoder resolution and off you go.
The ANALOG trigger option scans the first ANALOG channel you specify, looking for a transition across the threshold you specify. It does NOT look at the DIGITAL signal in an analog way.
