Help converting Labview 3 vi's to Labview 7.1
I was wondering if someone has the conversion package, would you please convert these files and send them back to me?
I don't have the package and need it kinda quick
Thanks!
Keith
kkirkwood at umail.ucsb.edu
(3,138 Views)
Attached taken to v6.  Had the usual "...uses data range coercion, which now only applies to data entry; values will not be coerced when passed to subVIs.  To coerce passed values,  use the In Range and Coerce function" warnings during the conversion.
Fading out. " ... J. Arthur Rank on gong."
(3,126 Views)
I couldn't mass compile in 3.1.1. It was moaning about not enough disk space on C: drive which was rubbish. So I needed to use 4.0.1 then 7.1. There are couple of bad vi's listed in the log.
David
(3,122 Views)
Thanks so much for the help
Keith
(3,100 Views)
