I have attached a zip which contains the converted llbs (from 7.0 to 6.1). The VIs which stand alone in the zip you attached use testand.llb, which I believe ships with testand 2.0.1, so those won't be useful to you unless you have testand installed. In any event, hopefully the converted llbs will give you what you need!
Thank you,
Best Regards,
JLS
