Help creating a string of byte data
I have some data in my VI in numeric form that I need to convert into a string in order to send it across my network by UDP.
Can someone show me how to do this?
I tried (see attached) but I'm loosing precision in the conversion to a string.
I need to stick to the following specs for my parameters
Parameter
Units
Type
Size (bytes)
Index
none
Integer
4
Lat
Radians
Double
8
Long
Radians
Double
8
Altitude
m
Float
4
Heading
Radians
Float
4
Pitch
Radians
Float
4
Roll
Radians
Float
4
4
Message 1 of 8
(4,463 Views)
Try the typecast function to do the conversion to a string.
Message 2 of 8
(4,460 Views)
Thanks!
Message 3 of 8
(4,456 Views)
And, it doesn't look like you are following the format you provided. It would seem you are converting everything to an array of U16s (two bytes).
Message 4 of 8
(4,451 Views)
One quick query...
I tried the type cast and it seems to convert the number to a string ok, but not as I expected.
For example (see attached), when I set the "Entity Index" to 97 I would expect to see the ascii chacater that represents the binary 1100001 i.e. "a". but instead I get "BÂ"??
I always need my string length for each paramater to be either 4 or 8 bytes long, as described in the spec above.
Message 5 of 8
(4,449 Views)
Well, now instead of U16 for everything, you've changed to SGL and DBL. SGL are 32 bit numbers (4 bytes) and DBL are 64 bit (8 bytes). You need to use the correct data types to begin with or use the convert functions before using the typecast.
Message 6 of 8
(4,436 Views)
Of course, sorry! Silly (embarassing) mistake Smiley Surprised
Message 7 of 8
(4,432 Views)
OK, here's the easy way (LabVIEW 8.0):
Sender: Make a cluster of your data, cast it to a string.
Receiver: cast it back to a cluster of the same type.
Couldn't be simpler! 😄 You don't even need to worry about sizes, etc.
Message Edited by altenbach on 04-12-2008 09:04 AM
Message 8 of 8
(4,430 Views)
