Help displaying.osm in labview
Hello everybody,
I have just startet a DIY drone project and want to display a map offline in my labview.vi . I have downloaded  a map section from openstreetmap as a .osm file via. http://extract.bbbike.org/. Is there any way to display this file type in labview. Or any other af the file types avalible from the site?
I hope you can help me.
-Mitch
(5,730 Views)
Hi Mitch,
when asking for "osm xml" you get text files in XML encoding scheme. You can read them with your favorite text editor!
Then you need to parse them to extract objects with their positions (lat/lon)…
(5,715 Views)
Thank you for your quick help. But unfortunately i understand nothing of it. I have never worked with xml files before and i am also still kind of new to LabView. If someone could help me with an example of how i can display an xml file in labview i would be very greatful.
Alternatively i have downloaded the map section as tiles including a .JSON file. would it be more easy to display them in labview?
(5,696 Views)
Hi MrMitch.
I don't have any experience with the .osm fileformat, so if you want to use that map, I would look more into what GerdW suggests.
However, another option is to integrate Google Maps into LabVIEW. Have a look at these two examples:
Community Example: Google Maps in LabVIEW
Forum: Google map API
I hope you can use this.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(5,678 Views)
BTW: Which DIY drone project are you working on? Smiley Happy
Best Regards
Alex E. Munkhaus
System Engineer
(5,672 Views)
Hello Alex,
I am working on my own project. I want to remote control a RC Plane with an arduino and an APC220 wireless communication antenna. The plane has a GPS-module and i want to be able to follow it on a map in labview and later i want to implement an autopilot so i can send waypoints to the plane. Right now i only can steer the plane via. a joystick through labview 🙂
Best Regards Mitch
(5,657 Views)
