Help: error 1097
I wrote a dll below simply to study string between labview & C++:
int strTest (CString pathCStr)
char* pathChar = "";
strcpy(pathChar, pathCStr.GetBuffer());
pathCStr.ReleaseBuffer();
return ((int)pathChar[0]);
The compilation was OK. But when I call it in labview, I was told
error 1097.
All parameters are correctly connected. Where is the problem?
Thank you!
(4,360 Views)
Hi Andrew,
I haven't had this problem before, but several related problems have been solved by this KB before.
Please look into that and see if it's helpful
Van L
NI Applications Engineer
(4,346 Views)
In your understanding of C. You've already allocated a fixed amount of memory by initializing pathChar. You can't use strcpy to copy a string onto that variable because you will stomp on memory that doesn't belong to pathChar.
(4,334 Views)
hello,
i have a simmilar problem. could anyone please take a look at following code:
// ant_sendevent.cpp : Definiert die exportierten Funktionen für die DLL-Anwendung.
#include "stdafx.h"
#include <stdio.h>
#include "ant_sendevent.h"
#include "extcode.h" //labview inlcude
#include <cstdlib>
//definitonen für ANT_Load und UnLoad
static HMODULE hANTdll;
static BOOL bLoaded = FALSE;
UCHAR *aucResponseBuffer;
UCHAR *aucChannelEventBuffer;
LVUserEventRef *antEvent;
LVUserEventRef *antResponse;
char* myeventbuffer[10];
char* myresponsebuffer[10];
//Functionen der ANT DLL
P_ANT_ARF         ANT_AssignResponseFunction;
P_ANT_AEF         ANT_AssignChannelEventFunction;
// Dies ist das Beispiel einer exportierten Funktion.
ANT_SENDEVENT_API BOOL ANT_Load(void)
   if (bLoaded)
      return TRUE;
   hANTdll = LoadLibraryA("ANT_DLL.dll");
   if (hANTdll == NULL)
      return FALSE;
   ANT_AssignResponseFunction = (P_ANT_ARF) GetProcAddress(hANTdll, "ANT_AssignResponseFunction");
   ANT_AssignChannelEventFunction = (P_ANT_AEF) GetProcAddress(hANTdll, "ANT_AssignChannelEventFunction");
   if (ANT_AssignResponseFunction == NULL)
      return FALSE;
   if (ANT_AssignChannelEventFunction == NULL)
      return FALSE;
   bLoaded = TRUE;
   return TRUE;
ANT_SENDEVENT_API BOOL ANT_UnLoad(void)
   if (hANTdll != NULL)
      FreeLibrary(hANTdll);
   bLoaded = FALSE;
   return FALSE;
//my CallBack Function for Events
BOOL ANT_ChannelEventFunction(UCHAR ucChannel, UCHAR ucEvent)
char* ucChannel_ = reinterpret_cast<char*>(ucChannel);
char* ucEvent_ = reinterpret_cast<char*>(ucEvent);
strcpy(myeventbuffer[10], (char*)ucChannel);
strcpy(myeventbuffer[10], (char*)ucEvent);
SendEvent(antEvent,myeventbuffer[10]);
return TRUE;
//my CallBack Function for Response
BOOL ANT_ResponseFunction(UCHAR ucChannel, UCHAR ucResponseMesgID)
char* ucResponseMesgID_ = reinterpret_cast<char*>(ucChannel);
strcpy(myresponsebuffer[10], (char*)ucChannel_);
strcpy(myresponsebuffer[10], (char*)ucResponseMesgID_);
SendResponse(antResponse,myresponsebuffer[10]);
return TRUE;
ANT_SENDEVENT_API BOOL functioncaller(UCHAR ucChannel_, UCHAR* aucResponseBuffer, UCHAR* aucChannelEventbuffer)
    aucChannelEventBuffer[MESG_DATA_SIZE];
aucResponseBuffer[MESG_RESPONSE_EVENT_SIZE];
    if(ANT_AssignResponseFunction != NULL  && ANT_AssignChannelEventFunction != NULL)
ANT_AssignResponseFunction(ANT_ResponseFunction, aucResponseBuffer);
ANT_AssignChannelEventFunction(1, ANT_ChannelEventFunction, aucChannelEventBuffer);
return TRUE;
return FALSE;
ANT_SENDEVENT_API void SendEvent(LVUserEventRef *antEvent, char* Eventmsg)
PostLVUserEvent(*antEvent,(void *)&Eventmsg);
return;
ANT_SENDEVENT_API void SendResponse(LVUserEventRef *antResponse, char*Responsemsg)
PostLVUserEvent(*antResponse,(void *)&Responsemsg);
return;
i always get the 1097 error but it seems i am way to stupid to solve this. i have read the kb article, but without any result (and i am net to c++ so its very, very hard)... please - could anyone help?
thanx
martin
(4,116 Views)
