Help file errors: Is settable when the VI is running?
Here's a curiousity from the Help File:
I was looking into the properties of the XY Graphs and found this:
Palette:Active Tool Property
Is settable when the VI is running? No
However, it is quite possible to read and update this property value while the VI is running.
From the documenation for the flags:
Is settable when the VI is running—Specifies if you can read or write a value from this property or method when the VI is running.
I've notice this for many other properties, too. Does anyone from the doumentation department read the forums?
LabVIEW 6.1
-dennis.
(2,483 Views)
The documentation for this property is also incorrect in LabVIEW 7.0, but has been fixed in 7.1. What other incorrectly documented properties have you noticed? If they are not fixed in 7.1 I will flag them to be fixed. Thanks for the feedback!
Robert Mortensen
Software Engineer
(2,463 Views)
