Help getting TDMS>Group>Channel>Values
I've tried using the TDMS Get Properties and TDMS List Contents, but I'm still stuck.  I think I have tried every combination of input: data types, channel names, and property names.  I thought maybe I needed to use the TDMS List Contents, but that only gives me the array of channel names of groups.
This is the only link I can find on TDMS Get Properties: http://zone.ni.com/reference/en-XX/help/371361E-01/glang/tdms_get_properties/
(2,751 Views)
Hi LabViewer35242,
From the title of your post, it seems you want to get the values from the channel, right? If so, you need to use TDMS Read to get all the data values.
(2,745 Views)
Still having trouble.  Something is wrong with an input or output from my TDMS Read.  I'm trying to get the timestamp values.
(2,733 Views)
For some reason it disconnected my "Time" input.  I think it is working now.
(2,732 Views)
You need to wire an array of timestamp as the input of "data" terminal of TDMS Read and then wire the channel name to TDMS Read.
(2,711 Views)
