Help in Driver matters
I found a power supply driver which require labview 6.0 or 7.0
I am using labview 5.0. Will i be able to use this driver?
Cheyne
(3,246 Views)
Not as is. You cannot open a VI written in a newer version of LabVIEW. If you post the driver, someone will, hopefully, be able to save it as 5.0.
(3,235 Views)
where can I find a driver which can be used by labview 5.0. None of the NI driver is below labview 5.0. Please help
(3,225 Views)
Can't help if you don't at least mention the name of the instrument and driver. Smiley Wink
Message Edited by Dennis Knutson on 02-02-2006 06:59 AM
(3,214 Views)
Duplicate Post
Please see responses to this question in the following two threads:
Thread 1
Thread 2
(3,199 Views)
