Help in labView
(3,053 Views)
You're supposed to attend the lab sessions and learn the answers as you go. If we give you the answers, you will learn nothing. The only one you would be cheating is yourself- out of an education.
(3,040 Views)
I see that you are working with some LabVIEW code, specifically a DAQmx system. DAQmx is a LabVIEW driver that allows customization of data acquisition devices. Also, I see that you posted a copy of your Lab Assignment. If you would like to learn more about DAQmx, then I suggest that you reference the link below which is a DAQmx Getting Started Guide that has some great videos to teach you how to program in LabVIEW using the DAQmx driver package.
https://www.ni.com/en/support/documentation/supplemental/06/getting-started-with-ni-daqmx--main-page...
Mike Watts
Product Manager - Modular Instruments
(2,995 Views)
