Help is needed to implement a PLL to obtain the angle of a three phase sinusoidal system
Im trying to develop the PLL to obtain the angle of the three phase system that allows to transform a three phase system into dq axes using Park transformations, there is any example?.
The voltages are obtained from an analogic module in the FPGA using a cRIO device.
(2,590 Views)
did you ever solve this problem, i am having issues with this as well
(2,456 Views)
