Help me to get correct data format from instrument buffer
I'm new in labview. I'm making a labview software to control  F900 Thermo Bridge
13 digits + CR + LF are returned in the form "+0.123456789B" + CR + LF, the first digit being
the sign, the last digit being the bridge balance status. Bridge balance status may be "B", "L" or
"H" or "E": for balanced, low, high or error (overload condition).
Data can be retrieved from the output buffer once per balance (program) cycle, which may be
two seconds or more, depending on the bandwidth setting and the signal being measured.
when i try to get data,  sometimes data format which i received is 56789E\r\n+0.1234 or .123456789E\r\n0   ...
I attached F900 user guide!
So you can give me some example to get data.
thank you so much
(3,056 Views)
Duplicate Thread
(3,038 Views)
