Help me to plot a 3D graph of aircraft trajetory by using the latitude,longittude and altitude of aircraft
Hi....I am 'anu' from india.
  I want to draw 3D plot of aircraft trajetory by using the latitude,longittude and altitude of aircraft is it possible with labview8.5. If you have any similar VI pls share. And is it possible to define a 3D object like aircraft, 2 axis moving objects?
Thanks in Advance
(2,900 Views)
If you have the LabVIEW Control Design and Simulation Module, we have some examples under .../labview 8.5/examples/simulation that could interest you, like the F-14 (examples\simulation\F14) or the (simulation\Aircraft Bank Angle Control).
In later versions of this Module, we improved the examples in Aerospace (LabVIEW 2010\examples\Control and Simulation\Case Studies\Aerospace) that demonstrate more use of Conrtrol Design and Simulation using 3D picture control, like the 6 degree of freedom F16 model. In this example we used the 3D Graph to define the trajectory to be used.
Hope this helps...
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,890 Views)
