01-15-2007 03:03 PM
01-15-2007 06:20 PM
01-15-2007 06:58 PM
01-16-2007 12:24 PM
01-17-2007 01:24 PM
Hello Sri,
It sounds like you are trying to use a digital start trigger to acquire for a specified period of time. By your statement about using the DAQ Assistant, I am assuming you are using LabVIEW with NI-DAQmx for your acquisition. Is this correct? I have several follow-up questions that will help determine the best method for you to proceed:
1. Are you using LabVIEW? If so, what version?
2. Are you using DAQmx? If so, what version?
3. What type of signal are you trying to acquire? Analog? Digital? Voltage? What frequency is the signal? What range?
All these questions will help you determine the best way to move forward. If you would like to view some options, there are several examples of using triggering available in the LabVIEW example finder. To access this application you can go to the Help menu in LabVIEW and select the “Find Examples …” option. From there I would recommend that you navigate to Hardware Input and Output>>DAQmx. Then select the type of acquisition you are trying to perform. Once you have determined the type of signal you are acquiring, you can look for any example with the phrase “Trig” in the title for an example of how to trigger you acquisition.
I hope this helps. Let me know if there’s anything else I can do to help.
01-17-2007 05:18 PM
01-18-2007 08:23 AM
Have a look at the example called Acq&Graph Voltage-int Clk-HW trig Restarts.vi
Change the start trigger to digital edge or give it a digital pattern and see if this will help you.
