Help needed:Real time generation of data
Hi all,
I am new to this group and labview also.My problem is that i have
to generate a continuous waveform for real time purposes from a text
file i have.I can read that but how it is possible to continuously
generate the data as a signal.
Can anybody know this
please share your ideas with me.It is quite urgent for me!.
I am adding the VI file and the data as text file.The VI file can read
my data (text file)and produce the waveform.All i have to do is make
it continuous and have to generate using the DAQ output.
If you have the code please let me know.
Thank you very much
Message 1 of 29
(4,779 Views)
Hi bharath_r…,
can you please attache your files?
Mike
Message 2 of 29
(4,764 Views)
I am attaching the VIs of reading the text data and the data input.
                                    Can we generate this in continuously as a DAQ output.and also iam refering the example from labview e\xample finder"Cont Gen Voltage Wfm-Int Cll-On-Board Regeneration".Can the integration of these two possible.?? i.e,the continuous generation of this data in analog ouput?
Bharath
Message Edited by bharath_reddy on 05-05-2008 01:57 AM
Message 3 of 29
(4,759 Views)
Hi mike
          can you consider the above attachments and please let me know the further approach.
Thanks&regards
 Bharath
Message 4 of 29
(4,738 Views)
Hi Bharath,
try this.
Mike
Message Edited by MikeS81 on 05-05-2008 11:56 AM
Message 5 of 29
(4,736 Views)
Hi mike ,
         It seems to be working.
         I have one basic doubt.What is that constant '1' that is given to attribute 'dt'.
         Is it that numeric constant or control or something other?If,yes it is not giving continuous output.
         Can you please tell me in which palette i will get that???
Bharath
Message 6 of 29
(4,723 Views)
Hi Bharath,
dt is the time between the y values in seconds. What do you mean with continuous output. You can create the waveform and connect it to, for example a DAQmx block. The card will then generate the connected signal.
Mike
Message 7 of 29
(4,720 Views)
Hope this helps!!!!
Mathan
Message 8 of 29
(4,717 Views)
Yes sir i know about 'dt', but i am not able to give a constant '1' as you given in your VI.
My doubt is where (in which palette) can i get the constant .
Is it the numeric control or constant??I tried those!!
Can you tell,though it is basic.
Bharath
Message 9 of 29
(4,715 Views)
ok thanks mathan.
I will try that.
Bharath
Message 10 of 29
(4,711 Views)
