Help needed with enabling the digital module
My current code: Once the captureIT.txt is found, the FPGA target in invoked and data acquistion is perfomed. I have used 20 Analog channels and 1 digital channel for data acquisition code.
But I need to add in a part where if Drive.txt is found, I will have to enable only one more digital module to high and not the rest.
Knowing that there can only only one bitstream file, How do I make changes in my realtime vi so that I can perform both the cases by invoking the fpga target once?
Any ideas on how do i proceed?
(2,680 Views)
Hi ravi_93,
I can think of 2 options
-Having 2 bitfiles in memory and configure the RT VI with a case structure containing the FPGA Open Reference pointing to one bitfile or the other.
http://zone.ni.com/reference/en-XX/help/371599N-01/lvfpgahosthelp/forcing_an_fpga_vi_to_download/
-Converting the FPGA VI into 2 similar subVIs with the necessary modification and have a case structure in the FPGA VI.
Regards
(2,621 Views)
