Help on changing array elements with For loop
I'm wondering if anyone can help me with this problem.  I'd like to be able to modify elements of an array with For loop.  In the attached VI, my goal is to have an array of [0 1 2 3 4 5], but instead what I've got is [2 2 2 2 4 5].  I initialized the array with a value of 2 to help me identify which elements are changing.  Can anyone help me pointing where my mistake is?  Thanks.
Peter
(2,743 Views)
It's a classic issue for LV newbies. In this case you HAVE to use a shift register otherwise the modifications of previous cicles are lost.
It's all easier than it's seems, see attached vi.
bye,
manga
(2,740 Views)
Thank you very much for your response, Manga.
(2,712 Views)
