Help on performing a Voltage Sweep with Keithley6487
Following my struggle to get a Voltage-Current Characteristics of an LED, i have end up with the following vi (VICharacteristicLED.vi).Still I am NOT getting the right Curve.
I have also attached the First VI (Loop2do.vi)that I got from an example and using the 6487 drivers itself, but it is unable to make a voltage sweep.
Please i will be very glad to get help from anyone, in order to use one of those 2 VI to make the voltage sweep and record the data in ascii.
(3,000 Views)
Hi
could you upload missing vi Display Table and Log  ??
xseadog
(2,998 Views)
Hi xseadog,
Here are the 2 missing vi and the main vi(Characteristic VI), the sweep voltage that i am trying to have is from -10 to +10V.
Thanks for ur assistance.
(2,989 Views)
Keithley provides a driver for this instrument on their website, which may be helpful:
http://www.keithley.com/support/keidoc_searchresult?keyword=6487&item_type=Software+Driver
(2,982 Views)
