Help, please! Unbundle data from serial string (com-port)
Hello Mihalis,
last work before weekend 🙂
I included my two subVi into your "serial_to_string" as "2_channels.vi" was password-protected...
Have a nice weekend!
Message 11 of 30
(2,269 Views)
Hello GerdW !
Thank you for the help!!!  Sorry to trouble you.
Have a nice weekend too!
Best regards, Mihalis.
Message 12 of 30
(2,260 Views)
Hello!
I need you help again! GerW, if you on-line, or anybody, help.
VI from previous message work correct (Unbundle data from serial string ), but one problem: if frame, which come from serial string starts from 11hex or 22hex (number of channel on my ATmega device), that all right, but if frame starts from other character (data, or end of frame symbol 0Dh), VI work wrong, because VI no account, from which character start scan from incoming string. (Need start scan from 11hex or 22hex).
How unbundle incoming string on 2 substring, each of which consist 4 bytes and first substring starts from 11hex and ends 0Dhex, and second substring srarts from 22hex and ends 0Dhex ?
I try use "scan from string" function, but I can`t do something Smiley Sad
Thank you!
Message 13 of 30
(2,243 Views)
Hello Mihalis,
have a look at "string_2_data.vi". There I show you a way finding the "start of frame".
See you tomorrow...
Message 14 of 30
(2,235 Views)
Hello GerdW! Thanks for answer! (tomorrow is come? Smiley Happy)
VI work, but problem is stay. If VI start scan VISA string from 11h, or 22h, that all right, but if VI start scan stringfrom  another simbol, VI is hover.
Message 15 of 30
(2,230 Views)
Hello Mihalis,
have a look at the subVi "string_to_data". It scans the string even with garbage in front of the data... And it works according to the test string (=default value).
What format has your data string? Can it include garbage between your data frames or just in front of the frames?
Message 16 of 30
(2,228 Views)
Hi GerdW!
 String don`t include garbage.
It consist 4 byte on first channel and 4 byte on second channel (11hex-lowbyte1-hibyte1-Dhex-22hex-lowbyte2-hibyte2-Dhex) in circle (1 and 2 channel fron ADC).
Message 17 of 30
(2,226 Views)
Hello Mihalis,
why do you want to start scanning your string NOT at the start of the frame? Why should your VI "hover" when the data always starts with 11h?
Have you seen my subVis?
Message 18 of 30
(2,223 Views)
Hello GerdW!
"why do you want to start scanning your string NOT at the start of the frame"
Because, when i start VI, it may start scan string from my device not at the start of the frame, but in the middle of frame, or at the end, and graph is plot wrong.
I seen you subVis, and I studing, how VI work.
One question (not on subject): I clearly writing on ENGLISH? Thanks!
Message 19 of 30
(2,221 Views)
Hello Mihalis,
so I suspect, your ADC is sending data all the time and you just listen to its broadcasting...
Try to see this data stream not as consecutive clusters but just as a byte stream. Then it is perhaps easier to extract the data you need (changing concept from "typecasting to cluster and unbundle" to "extract bytes from stream and append to correct array (ADC1/ADC2)").
On your question:
I'm not a native English speaker and I think you're also not. But we can express our thoughts and that's it.
Message 20 of 30
(2,218 Views)
