Help regarding SMTP Email Send Message
Hello everyone,
i am working on the SMTP Email Send Message using labview .  i have connected the terminals as suggested in the Context Help and i can run the VI but a keep getting a lot of errors.
Needless to say i cant send the mail .
i have enclosed the vi , shall be grateful if somone can suggest any modifications so that the VI works.
I have also seen the GMAIL.vi but dont want to use as it seems complicated.
Thanks in advance
Message 1 of 15
(5,837 Views)
Hi Sindhurakshak,
I have checked the code and it's working fine for me. I think the problem is with your SMTP server. Please check SMTP server name adn try it it should work.
For shake of testing I have changed the SMTP server name and it works fantastic.
Message 2 of 15
(5,817 Views)
hello Pankajusic,
Thanks for reviewing the code.
 i was under the notion that the SMTP Server remains the same for a given company . For example, for google it is smtp.gmail.com and the like.
Request you to post your vi with the modifications you have made.
Further , how i can i find my SMTP server name ?
I am using LabVIEW 2011.
Regards
Jalashwa
Message 3 of 15
(5,805 Views)
Are you sure Gmail's server will take SMTP mail?  I don't think it does because it would be and easy gateway for spam.
You need your company's e-mail server, and them set up to allow you to give it smtp mail based on that fact they should have already authenticated your PC on their domain.
Message 4 of 15
(5,803 Views)
Hello Ravens Fan,
i delved more into SMTP in Google and found out the following steps:
  1. Open up a command prompt (CMD.exe)
  2. Type nslookup and hit enter
  3. Type set type=MX and hit enter
  4. Type the domain name and hit enter, for example: google.com
  5. The results will be a list of host names that are set up for SMTP
I am attaching a pic of my cmd after executing the steps. I updated the mail server in the SMTP Email Send Message block diagram and i got an error. i have also attached the pic for that
It would be very kind of you if you could guide me through
Regards
Jalashwa
Message 5 of 15
(5,793 Views)
A little off track with regard to solving the specific problem, but to answer RavensFan's point:
Yes, Gmail does allow you to use SMTP. This is how you use other email clients (Outlook, Thunderbird etc) to send/receive things from your gmail account.
(a quick Google confirms this).
Message 6 of 15
(5,785 Views)
I have chnaged smtp  name as per our company mail server and it's worked fine. that is the only chnge i did there.
I found something on internet that might help you.
https://forums.ni.com/t5/Example-Code/GMAIL-vi/ta-p/3996207
pankaj
Message 7 of 15
(5,756 Views)
In order to use Google's SMTP server function, you must authenticate using TLS/SSL.
The LabVIEW SMTP functions are natively written in LabVIEW and have no support for TLS/SSL.
Message 8 of 15
(5,747 Views)
thanks for the info ,
i have tried others like yahoo and rediff.com but i just cant get over the errors i am getting
Regards
Message 9 of 15
(5,735 Views)
That document is out of date.  LabVIEW 2013 has had email VIs revamed tp support TLS.  I've not used these but remember it from the release notes.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
Message 10 of 15
(5,729 Views)
