Help regarding labview model
So. please help me regarding this . How will I do it. Please send me model or Image from which I can understand how to do.
Thanks alot
Message 11 of 19
(4,205 Views)
I think you need to figure this out for yourself. I gave you all necessary information.
If you can't, maybe programming and signal processing is not for you.
Message 12 of 19
(4,201 Views)
how to calculate the time taken by each sample in this case.
Message 13 of 19
(4,173 Views)
What "case"?
Message 14 of 19
(4,158 Views)
thia attached
Message 15 of 19
(4,154 Views)
You are still not making any sense.
Your reference signal has 12 points, so your generated signal should also contain 12 points (not 13!), otherwise you are throwing away part of the data. If you change the frequency or samples/second, you are no longer matching the reference signal, but measuring some poorly matched number of cycles.
If you simply want to generate a signal that has a different phase at each iteration, change the express VI to again reset the signal with each call, but now simply wire a new phase based on a multiple of the iteration count. See how far you get.
Message 16 of 19
(4,130 Views)
how do you create that black block. can you send me that pic of e^jtheta block
Message 17 of 19
(3,969 Views)
Check out Polar to Complex in the Mathematics toolbox, it should do the same.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 18 of 19
(3,965 Views)
Thank YOU
Message 19 of 19
(3,961 Views)
