Help searching hexidecimal string.
Do you mean 2E as a string (a 2 and a E), or as the character 2E?
Regular expressions don't work too well with non-ascii codes. 2E is a
decimal point, so that shouldn't be a problem. But if your string indicator
is in hex mode, you'd see 2E, but a reg. exp. won't find 2E.
Wiebe.
Message 11 of 14
(763 Views)
That is because 2E (.) is a reserved character for regular expressions. You
have to escape it with a backslash: "\.".
Wiebe.
Message 12 of 14
(749 Views)
I was actually trying to use the 2E as a decimal point for the regular expression (wild character).  Looks like a problem in LV8.0, as it works in 8.6 (which i dont have application builder for.).  Oh well guess ill do it the long way, thanks again for all the help. 🙂
Message 13 of 14
(741 Views)
"dirtyb15" <x@no.email> wrote in message
news:1219839007594-768011@exchange.ni.com...
expression (wild character).&nbsp; Looks like a problem in LV8.0, as it
works in 8.6 (which i dont have application builder for.).&nbsp; Oh well
8.0 should be forbidden. It's only good for converting >8.2 code to 7.1.
Wiebe.
Message 14 of 14
(737 Views)
