Help to resolve the problem with incorrrect chinese code saved to SQL
1. SQL used is SQL 2008, in server side.
2. LV used is LV86,
3. Issue is: the chars saved to SQL is not chinese code, which is not readable, pls. help advise how to implement the below syntax in Labview by using DB tool insert data.vi of database toolkit..
MyTable(name,url) values('weste.net',N'西部e网')
Thank You Very Much.
Johnson
Message 1 of 1
(2,316 Views)
