Help - trainee position application
I'm a third-year french student (Bac +5), preparing a three-year
engineer diploma in Automation & Microelectronics, and I'm looking for a
trainee position in the field of Automation, and I'm expecially
interesting in using Labview because I have already good skills about
this soft.
So, I would like to get contacts to argue about my skills and my
motivation. I'm available from 1st February 2000 for a 5-month minimum
period...
Thank you...
(4,934 Views)
Monsieur respecté,
I m almost in the same position in which you faced in 1999, I just want to speak with you. Kindly revert me back
(3,788 Views)
In 1999 we had LabVIEW 5.0. That year, in May, LabVIEW RT module was released. LabVIEW FPGA would not see the light of day until four years later. 1999 was actually closer to the first ever release of LabVIEW (13 years) than to this day (19 years). Mr. Richier, who wrote this single post on the NI forums, probably doesn't even remember that he's ever done this, he might even not remember clearly what LabVIEW is at this point if he changed his career path...
I'd strongly advise you to review your job searching strategy
(3,776 Views)
I think this might hold the record for the oldest thread resurrected here.
Bill
CLD
(Mid-Level minion.)
(3,751 Views)
You're probably right.  The message ID is only 3 digits.   #226
(3,747 Views)
WOW.
With some message boards, the old threads are usually archived and read-only.
(3,742 Views)
