Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Help using invoke node 'Ctrl Val.Set' with cluster elements
Re: Help using invoke node 'Ctrl Val.Set' with cluster elements
smercurio_fc
Knight of NI
04-10-2009
03:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
You can always still use the control reference method as I had described. Attached is a modification of your VI that does this.
Program (ref).vi 22 KB
0
Kudos
Message
11
of 11
(789 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
